EmSshi's avatar
EmSshi
RAX200 randomly rebooted
Hi guys,
These days, my router rebooting often occur.
I checked the firmware update and reset the settings, but the symptoms are still there.
Could this be caused by hacking attempts? What can I do for this?
Thanks for your help.
This is the latest RAX200 firmware version in use.
V1.0.3.106_1.0.58
This is the log right after rebooting.
[Time synchronized with NTP server] Thursday, Apr 29,2021 23:53:18
[DoS attack: RST Scan] from source 13.225.105.62,port 443 Thursday, Apr 29,2021 23:51:25
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 23:47:50
[DoS attack: RST Scan] from source 142.250.206.238,port 443 Thursday, Apr 29,2021 23:47:19
[DoS attack: RST Scan] from source 34.236.182.175,port 443 Thursday, Apr 29,2021 23:44:40
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 23:35:07
[DoS attack: RST Scan] from source 18.215.9.186,port 443 Thursday, Apr 29,2021 23:34:09
[Time synchronized with NTP server] Thursday, Apr 29,2021 23:23:18
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 23:21:48
[DoS attack: RST Scan] from source 23.212.14.11,port 443 Thursday, Apr 29,2021 23:09:32
[DoS attack: ACK Scan] from source 23.35.220.127,port 443 Thursday, Apr 29,2021 23:09:19
[DoS attack: ACK Scan] from source 23.35.220.22,port 80 Thursday, Apr 29,2021 23:09:15
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 23:07:22
[DoS attack: ACK Scan] from source 13.224.8.22,port 443 Thursday, Apr 29,2021 23:03:24
[DoS attack: ACK Scan] from source 23.51.28.20,port 443 Thursday, Apr 29,2021 23:01:19
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 22:54:40
[Time synchronized with NTP server] Thursday, Apr 29,2021 22:53:17
[DoS attack: RST Scan] from source 142.250.206.238,port 443 Thursday, Apr 29,2021 22:44:47
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 22:43:02
[DoS attack: ACK Scan] from source 23.212.12.41,port 443 Thursday, Apr 29,2021 22:30:17
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 22:28:53
[DoS attack: snmpQueryDrop] from source 193.118.53.197,port 45917 Thursday, Apr 29,2021 22:25:47
[Time synchronized with NTP server] Thursday, Apr 29,2021 22:23:18
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 22:17:15
[DoS attack: RST Scan] from source 18.215.9.186,port 443 Thursday, Apr 29,2021 22:12:58
[DHCP IP: (192.168.1.10)] to MAC address 78:11:DC:EA:D7:5B, Thursday, Apr 29,2021 22:04:31
[Time synchronized with NTP server] Thursday, Apr 29,2021 21:53:18
 Thursday, Jan 01,1970 09:00:00
  • plemans's avatar
    Did you reset or reboot? By reset I'm implying a factory reset. Push and hold reset for 7-15 seconds while its powered on.
    Is it automatically rebooting?
    Have you tried a different outlet in case its a power issue?
    Did you try reinstalling or downgrading the firmware in case thats the issue?
    • EmSshi's avatar
      EmSshi
      In this case, it will reboot suddenly without any notice.
      I couldn't change the power because there were no other products.
      Even if I changed the firmware that come from netgear public support center,  it's a private firmware, I reset and reinstalled it, but the symptom did not improve.
      They will replace or repaire with RMA through official support.
      Thanks for your comment.
