retiredat56
Jan 20, 2021Aspirant
RAX200 Reboot and NO IP Address
I have an RAX200 WIFI router. Whenever I reboot my RAX200 and modem, I cannot get an IP Address for any of my devices. My PC will not reconnet and it says No Ethernet IP address. My phone will not reconnect saying No IP Address. I don't understand why the router will not reconnect automatically. I reboot the router and modem together. No Joy! I reboot the modem first leaving the router off until the modem comes back up. No Joy! I reboot the router first leaving the router off until the router comes back up. No Joy! During these situations, I leave off my PC, or I leave it on. Again, No Joy in any reboot sequence. My only fix is to perform a Factory Reset on the RAX200. This fixes the IP Address issue by running the setup on the router. As it fixes the issue of No IP addresses on any my devices, I cannot believe this is what you should have to do each time your have to reboot the router. HELP!!!! What is the correct router reboot sequence without having to perform a router factory reset before I can get back up and running with IP address for my devices? Tks, MIKE
What modem/gateway do you have?
- plemansGuru - Experienced Userand what firmware is it on?
- retiredat56Aspirant
Firmware is RAX200_V1.0.3.106_1.0.68 (I believe the latest)
Modem is an Arris SB8200
I've rebooted other routers and never consistantly lost the IP address for my devices. I was even instructed to run IPCONFIG /RELEASE and IPCONFIG /RENEW off my PC to help fix the issue, but with no success.
Are you using wan port aggregation? If so, disable it. The SB8200 has had issues with wan port aggregation.
Never turned on Ethernet Aggregation. Confirmed it was disabled.
In the SB8200's disabled as well?
I've got both the SB8200 and the RAX200.
I usually just boot up the sb8200, give it a few minutes to fully boot, then boot up the rax200.
I'm even on the same firmware with the rax200
I logged into my Arris SB8200 and confirmed that Link Aggration was disabled. (I have never enabled it).
Tried replacing the ethernet cord between the 2?
Who's your isp?
Cord replaced. ISP is Comcast/Xfinity.
Rebooted my router again. No IP address for any of my wireless items on my network when the router came back up.
:smileysad:
- nguyenthuyenAspirantsimilar to the above case
I am using netgear Rax200 router.
I have tried updating the version 1.0.4.120 with the Nighthawk app, but a few times failed. May be Internet singalI. I tried restart again and then it was failed.
Now, Power LED is blinks slowly and continuously, the router firmware is corrupted. This happen while i am firmware update is interrupted, the router detects a problem with the firmware.
I can't login to the router with a PC, it does not have a WiFi signal to login by iPhone.
Pls help me!
