YoungSpicket's avatar
Oct 09, 2019
RAX200 WAN Aggregation auto QOS bug
On current and shipping firmware, RAX200 will cut wired and wireless internet speeds in HALF when WAN aggregation is active. This appears to be a bug with WAN aggregation implementation during channel bonding that the RAX120 does not have.
Note RAX200 Disables QOS when WAN aggregation is active but somehow still seems to cap wired and wireless speeds at 500mbps despite gigabit plus connection. Speedtest in router UI shows 1400mbps. Internet speeds to all devices connected to router via any method are capped at 500mbps. Speeds work as expected when using WAN points by itself with aggregation disabled.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    YoungSpicket,
    Thanks for bringing this up. I'll have this escalated to the team and I'll provide an update as soon as possible.
    Christian
    • Thanks Christian. Also, I noticed that there seems to be WPA2 authentication issues after changing wifi settings (at least on the 5ghz band), sometimes it won't except the saved wifi password until another reboot of the router.
      As an aside, besides naming both 5ghz bands the same name, is there a way for the router to smartly balance between the 5 ghz bands WITHOUT the 2.4 band ala the Asus AX11000, which i believe shares a chipset with the AX12 triband.
        Christian_R
        Hi YoungSpicket,
        I have sent you a message with further questions for further isolation.
        Christian
