Randy_Wu
May 15, 2020Aspirant
RAX200 Wan Aggregation
Hi I am looking to purchase an RAX200.
If my modem has a 1Gbps coming out from port 1 and port 3, am i able to set the Wan aggregation?
Randy_Wu wrote:Hi I am looking to purchase an RAX200.
The RAX200 supports wan aggregation. Does your modem? They both need to support link aggregation, not just the router.
what modem are you using?
- Randy_WuAspirant
HI,
How do i know if the modem supports wan aggregation.
From what i tried i have a PC which has 2 lan ports and i do a link aggregation on the PC i am getting around 1.5Gbps.
I am assuming if I plug the 2 lan ports into the RAX200 i should be getting the same kind of performance when doing the wan aggreagation.
- plemansGuru - Experienced UserWhat modem is it?
