DrPhoggy
Jun 04, 2022Tutor
RAX200 Websites not loading
I’m using the RAX 200, which has worked beautifully to this point, but I’ve recently had a problem where certain websites are not loading when connected to my home Wi-Fi network. The same websites load fine using cellular data and load fine when connected to other Wi-Fi networks (at work, for example). The problem is more severe when using Safari. I’ve rebooted the router, refreshed the internet through my ISP, and tried a variety of software settings on my iPhone. Nothing affects the problem. It seems there’s some issue with how the iPhone is communicating with the Netgear router.
what modem/gateway do you have?
What firmware is on the router?
Do you have IPv6 enabled?
have you tried a different dns server for both ipv4 and ipv6?
- DrPhoggyTutorWe have the standard Google Fiber modem, and the current firmware for the router V1.0.6.138. I don’t know about IPv6. I don’t see a setting for that specifically on the Nighthawk app, so I apologize for my uncertainty about that.
what standard google modem is it?
try enabling ipv6. Its done through the browser and not the app.
How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
