Synomenon
Apr 27, 2020Star
RAX200 "Wings" don't click or snap into place?
Do the RAX200's "wings" really not snap or click into place? They seem to just sit there, unsecured. I followed the graphic on the stickers found on the wings.
- psychopomp123Luminary
Hi,
The wings of the RAX200 do clip into place - once you flip them open into the vertical position then you push them down slightly until you hear a gentle click. To fold them, you reverse the process. But they do seem a bit flimsy, because even when they're in the locked position they still move about slightly.
Cheers
I don't hear any "click" when I place them in vertical position then push them down. There's no resistance or reassurance at all that they'll stay there.
In that case you might have a faulty unit. I suggest asking Netgear if they can send you a replacement under warranty.
- RajaDajaLuminaryGently push down on each wing, this should lock it in place.
As mentioned above, I did push down on the wings. They do not "lock" into place. After watching some video unboxings and reviews, this seems to be normal for the RAX200 which is disgraceful for such an expensive router.
- RajaDajaLuminaryNot the norm. Mine work as they should.
- RajaDajaLuminaryYou could gently push down on each wing, see if that closes the gap a little. My opinion.....it’s designed like that. My gap is about the same as yours.
