sharkuae's avatar
sharkuae
Follower
Jan 03, 2021
RAX200
Dear support team,
I have two device RAX200 and both of then the lan connection stop working when i try to connect using lan cable and i can access the device using only wireless soultion and sometimes device will not respond for wireless as well.
V1.0.3.106_1.0.58
GUI Language Version
V1.0.3.106_2.1.46.1
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello sharkuae,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
