Taddeusz2002's avatar
Taddeusz2002
RAX29 UDP Port Forwarding
I've recently had to upgrade our router. I have a Nighthawk RAX29 with the latest 1.0.9.92_1 firmware.
I have an Unraid server configured with a WireGuard VPN. This worked flawlessly on our old router. The router doesn't appear to be port forwarding the UDP connection. I also have a TCP port forwarded that's working fine. When I go in to edit my WireGuard port it shows it as TCP even though I've previously selected UDP. Even if I select TCP/UDP when I go back in to edit it still shows TCP is selected.
  • I'm running V1.0.9.92_1 on RAX30 and encountered the same problem.  No matter I chose TCP/UDP or UDP in custom services, the setting always reverted back to TCP!!!
    • Taddeusz2002's avatar
      Taddeusz2002
      I had to switch browsers. Safari on macOS was not working. I can’t remember which browser ended up working for me so just try different browsers.
      • michaelkenward's avatar
        michaelkenward
        Many Netgear manuals say things like:
        "This recovery process is supported in Internet Explorer, Firefox, and Chrome browsers, but not in the Safari browser."
        Not sure what else it affects.
