Nick8810
Dec 02, 2022Tutor
Rax30 Nighthawk
The Wi-Fi keeps dropping. The Wi-Fi signal is strong, have not had a problem for about 6 months till now. The wired connections work with no problems. Any suggestions to fix the problem?
Using the 2.4 nothing on the 5g side
It only happens on the 2.4ghz side?
Have you tried changing what channel you broadcast on? 2.4ghz is sensitive to interference and maybe something is broadcasting on it.
- BarbaramcgroreyAspirantThe internet has been blocked. How do I fix it
