pilon29's avatar
pilon29
Initiate
May 09, 2020
RAX35 - Confused about installation
Folks
This may be a stupid question and I apologize. I just installed the RAX35 Router and realized it came with a CAT 6 Cable but no phone cable and there is nowhere to plug the line from the wall into the router. Do I need to purchase another piece? I was trying to replace the old Modem/Router that the internet provider gave me. I got it working but right now it goes
From the wall jack tinto the internet plug using a regular phone cord, then I plugged the cat6 cable into the old modem/router (port 1) then into the internet port in the back of the nighthawk. Does this sound right? I was hoping to get rid of the old modem/router.
Thanks in advance for any help.
  • plemans's avatar
    The RAX35 is a router only. it isn't a modem. If you have dsl, you'd need a dsl modem.
    If you're prior setup was a dsl modem/router device then you might still need to use that device but place it in modem only/passthrough mode.
    • pilon29's avatar
      pilon29
      Initiate
      Thank you very much. I found the instructions to set it to modem only.
