DoubleIpa
Oct 14, 2020Aspirant
RAX35 cant log into router
For the last 7 days i am unable to log into router to change settings. I tired going through IP address and also the cell phone app. I have wireless and wired connection working with no problems. However i can not add a new deivce to wifi. The only way to access the configuration is to reset to default setting. I have the latest firmware.
Any ideas...
thanks
- itsmehueyLuminary
do you run into any errors? Internal Error 500 error page perhaps? If so, you're most likely going to need to revert back to the previous firmware version.
- DoubleIpaAspirant
i downgraded the firmware...turned of AX and everyday the netgear router drops connection...i am unable to join new devices nor can i log in...have to perform a default reset and start over..
thanks
