crewsn01's avatar
Jan 01, 2020
RAX35
New problem with the RAX35 again.  I have purchased a new Arlo Video doorbell and I have tried for the last 3 days to get it to connect to this router with no luck and seems when I try to connect the router appears to disconnect.  I tried one of my older routers (Netgear) and it connects so I know it is not the doorbell.  I also tried to the guest wifi and it will also not connect.  If anyone has experience with this issue I sure would appreciate advice to get it connected.  I have not called Netgear yet. Thanks
  • I know the Arlo doorbell will connect with AX device because I've connected to my RAX with my arlo doorbell. But when I setup my doorbell the first time, I was running on a standard AC router (orbi) and then upgraded to the RAX later. So if you still have the old router, set it up using that and make sure your using the same ssid as your new RAX. That way when you power off the old router and turn the RAX back on, it'll be searching for that ssid.
    A little bit of a work around.
    A different option you could try would be to disable the AX feature on the router. If you do this, make sure to reboot the router after you disable it and save the setting. Sometimes this helps.
    • crewsn01's avatar
      crewsn01
      Tutor
      Thanks for the reply but none of these options worked.  The Arlo Video Doorbell still could not find the router.  Still need help in resolving this issue.  3 days is too long to be trying different options to make this router connect.
      • labatt's avatar
        labatt
        Mentor
        Have you contacted Arlo support? There is a support phone number on their site, unlike Netgear router support.
