aqualita's avatar
aqualita
RAX40 — Nighthawk AX4 4-Stream WiFi Router
my RAX40 — Nighthawk AX4 4-Stream WiFi Router switches off the internet all the time after the latest firmware update,  what to do
1). windows 10 Home 64 bit
2). Fastvareversjon V1.0.3.80_1.0.1 ( router)
regards from
Tore Braathe
Norway
1 Reply
  • plemans's avatar
    anytime there's an issue after a firmware upgrade, a reasonable first step is  factory reset.
    If that doesn't help, then I'd downgrade the firmware to the older version. Maybe the newer one introducted a bug in your device.
    Once downgraded, disable auto updates so it doesn't automatically go back to the problem version.
