talmai
Aug 22, 2020Aspirant
RAX40 Drops internet and has to be rebooted almost daily
My RAX 40 started to drop internet connection almost everyday for the past two weeks. Need to reboot and the internet is back. Firmware V1.0.3.80 App version 2.6.0.13 I checked and there's no new f...
NetLimbo
Dec 19, 2020Aspirant
Thanks for the response. I was truly hoping that would not be the answer. So, my choice is to take the risk on V1.00.3.88 or fall back to the one older than V1.00.3.80, which is V1.00.3.64. I have not seen much feedback on the 1.00.3.88 on this model.
itsmehuey
Dec 20, 2020Luminary
NetLimbo wrote:Thanks for the response. I was truly hoping that would not be the answer. So, my choice is to take the risk on V1.00.3.88 or fall back to the one older than V1.00.3.80, which is V1.00.3.64. I have not seen much feedback on the 1.00.3.88 on this model.
The only feedback I have is that it works without any dropouts so far but sacrificing some features like WPA3 which is an absolute joke as the router was advertised with WPA3 compatability..
- Chana88Dec 21, 2020Apprentice
Best thing you guys can do is bin the RAX40 and get another make like I have done I have no drop outs at all got all the features that they have disabled WiFi is much better and all devices connect correctly. At least they can do Is give us version 2 of this model free of charge as version 1 is not fit for purpose. I know it's not the best solution but netgear have gone down in my opinion and support is next to none, won't buy any netgear product again.
- RDA1074Jan 14, 2021Aspirant
This problem is STILL persisting.
You know I am not seeing any manufacturer effort to correct this problem.
@LinusTechTips
@UnboxTherapy
I'm going to start hitting Linus and Lew on their channels until they talk about it.
NETGEAR - are you awake yet?
FIX THE ISSUE. It's ridiculous that it has been like this for so long...
- Chana88Jan 14, 2021Apprentice
Go for it
I use mine as a door stop
