Paranjape_Raja's avatar
Dec 30, 2022
Rax40 won't connect to a web site, times out
I used to be able to connect to a bank website that no longer connects with my RAX40 WIFI6 ROUTER. It just times out. I have done modem and router reboot in succession, but this does not restore access. If I put RAX 40 as a second router behind an old router, it connects to that website with both wired & wireless connection. But, now my speed is limited by the 1st old router.
  • michaelkenward's avatar
    michaelkenward
    No other useful messages?
    Which browser?
    Is that the only site that blocks you?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    • Paranjape_Raja's avatar
      Paranjape_Raja
      I tried with MS Edge, Firefox, Google chrome, all with the same result.
      Error message:. Connection timed out. Server did not respond in 30 seconds
      I am using windows11. PC is hard wired using Ethernet. If I put my old Trendnet 300 router as primary and RAX 40 Netgear as a second router connected to the 1st router with Ethernet cable, the same PC connected to RAX 40 connects to that web site. But, this does not work when RAX40 is used as a primary router. RAX 40 is a faster, better router with 1200 Mbps. So making that as secondary router lowers overall internet speed from 300 Mbps to 100 Mbps. That's why, I would like to understand what's wrong and fix it to be able to fully utilize it's capability. My firmware is the latest update and this router was able to connect to the website two months ago in primary position. I have tried doing factory reset by poking a pin in the hole on the back of the router and rebooting the entire network modem 1st, router next, but it no longer connects to that website in primary position. Any suggestions to try would be most welcome.
        michaelkenward
        That raises another question, it might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
        The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
