Jostl21
Jun 28, 2025Aspirant
RAX42v2 5GHz band failing
Hey all, I’ve had this router for 6 months, and in the last couple weeks, the 5GHz band is failing daily. Restarting the router helps sometimes, other times the band isn’t broadcasting at all and...
CrimpOn
Jun 29, 2025Guru - Experienced User
Jostl21 wrote:The firmware is up to date
Firmware is v1.1.4.28 ? (sometimes "up to date" reflects the device not detecting the latest firmware)
When there is a problem with the 5G WiFi, can devices still connect to the system at 2.4G?
This model has the ability to set up a WiFi schedule. Can you verify that no schedule has been defined? The Product Data Sheet mentions the ability to control the router with voice, using Alexa or Google Voice. Is this feature enabled?
- Jostl21Jun 29, 2025Aspirant
The downloads page for this model shows the same Firmware version.
There are not parental controls (schedule) set, and smart device integration is disabled.
The slower band continues to work despite the 5GHz going down. I’ve also set it to 3 different unused channels based on the other networks around me.
- FURRYe38Jun 30, 2025Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- Jostl21Jun 30, 2025Aspirant
Yes, that was my last attempt. The first time was via app, the last was from this wired desktop + web interface. Also gave a few minutes unplugged each time I tried factory reset.
As of this morning, it's made it from yesterday morning to now with a functional 5GHz band, I guess I'll see if it makes it all day or not.
