larrydrum
Apr 01, 2021Aspirant
RAX43 internet light is red
I've check the manual and there is nothing that say what a red "internet" light means. I have internet access and everthing is working. Performance is good at about 570 mbps.
Desktop Computer and VOIP Phone is the only item connected to the LAN ports.
Modem: Netgear CM1200
EX7500 Extender (upstairs - Don't know if I still need it, but it is working.)
Thanks for any clarification
Larry
- larrydrumAspirant
I think I found solved it. On this router the red light indicates that you have a LAN connecition. On my older model R7000 it did not turn read unless I did not have internet connection.
- Christian_RNETGEAR Employee Retired
Hello larrydrum,
Thanks for providing an update to your post as it may possibly help others in the future.
Christian
