ChuckLud's avatar
ChuckLud
Initiate
Nov 07, 2022
RAX43 N71 AX 4200 wireless router
Have the above wireless router.  Worked fine for 6 months then can't connect with the 5G band.  Is the first step to reset/reboot the router.  Then reboot both the cable modem and then the router.  Y...
