achris51
Mar 22, 2023Aspirant
RAX43 randomly drops internet routing.
I am having a heck of a time figuring this one out. In general the router works pretty good, but at times it's frustrating to use. This is the second one that I have bought but that isn't really rele...
Mar 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
microchip8
Mar 28, 2023Master
I have 14 devices constantly connected to my RAX43 using the same (latest) firmware as you, and none drop out or have connection issues - they've been up for 94 days by now. Since it's not clear to me what your problem might be, I'd suggest doing a full factory reset (button at back of router) and manually configuring everything. Please do report back.
