Fowler's avatar
Fowler
Follower
Oct 04, 2024
Rax43
When everything connects, it works fine for about 40mins. All the lights on the router stay white but I lose connection to all devices, it will re-connect after 40 mins or a power cycle and work for 40mins and stop again. It almost seems like a 40min on and 40min off setting or something. I have an older 6260 router with no issues and also a TP-link. My provider is Point Broadband and use a Poe for internet. It seems like something internally stops allowing internet to pass through, but the router still thinks its connected.
1 Reply
  • FURRYe38's avatar
    So the Internet LED on the top of the router remains WHITE when this happens? No AMBER is seen at all?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
    Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
