UABMaddog
Dec 12, 2025Aspirant
RAX43V2 firmware update?
I have tried to update my firmware on my RAX43V2. The router shows/says that there is a firmware update available but won't install it. I have tried manually installing from the downloaded file. ...
Dec 22, 2025Guru - Experienced User
So was this issue fully solved and you were able to get the router fully updated?
