wsamh's avatar
wsamh
Follower
Mar 12, 2021
RAX45 - had to factory reset twice
I have a RAX45 router. the last couple of weeks I've had to factory reset. the first time, for some reason all my device could not connect. nor the connecting directly with ethernet. Just today the wifi was not showing up and and connecting directly with ethernet was not working either. the router is only 3 months old. any Ideas or do I need to get a new router.
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello wsamh,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
