billrobpv's avatar
Mar 23, 2021
rax45 delete (close) a guest network
I have an RAX45 nighthawk and windows10.  I have somehow created 2 guest networks, one on 2GH band (admin) and a similar one on 5GH (admin5g).  I want to get rid of them, but deleting the names, etc. does not work.  How do I delete/close a guest network?? Thanks Bill Roberts (billrobpv).
  • I've seen it before where a bug leaves the guest network enabled. Not sure if thats the case in yours.
    You can always try a factory reset. Push and hold reset for 7-15 seconds while its powered on. Then reinstall it.
    See if that fixes the issue.
  • I forgot to add that guest betworks are NOT enabled, and I have unchecked all the option boxes that I could.  billrobpv
  • plemans's avatar
    • billrobpv's avatar
      billrobpv
      Tutor
      Success!!
      I think my problem was a: not complelely inserting the paper clip into the reset hole or b: not holding it in long enough.  In any event, a complete reset/reboot deleted the Guest networks.  Thank you for the help.  Bill Roberts
