jweegar
Aug 12, 2025Aspirant
RAX45 log entry: [Internet disconnected]
Anyone know how to approach this issue? Perhaps router needs to be replaced? Internet disconnect happened last week and then again today. Router is running latest Firmware: V1.0.17.142_2....
Aug 12, 2025Guru - Experienced User
Does the RAX WAN/Internet LED turn AMBER or RED when this happens?
What is the model # of this ATT ONT that the RAX is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
Is IPv6 enabled on the router?
Using ISP detected DNS or custom DNS like Cloudfare or Quad9?
