amonynuts
Jan 12, 2022Apprentice
RAX45 missing Remote Management option under Advanced Setup
Model: RAX45-100NAS Nighthawk AX6 AX4300
Firmware: V1.0.4.100_2.0.64
In the routerlogin.net configuration menus, I find no option to enable Remote Management under Advanced -> Advanced Setup or under Advanced -> Web Services Management.
Is Remote Management no longer available on Nighthawk routers?
Remote Mangagment was removed from NG routers. I believe it may have been due to a security concern. So there using the mobile NH app and Access Anywhere feature on the app to be able to remote in to the router using the Nighthawk app.
- amonynutsApprentice
That's unfortunate since the Nighthawk app doesn't run on my laptop/desktop computers, and doesn't allow modification of many configuration settings. Thanks for the info.
Ya, for any advanced configuration changes, you'll need to be local with a PC or laptop and web browser.
