AndyPi's avatar
AndyPi
Follower
Jun 18, 2022
RAX45 Port forwarding rule not accepting comma
Firmware V1.0.11.112_2.0.77
Trying to add a UDP port forwarding rule and no matter what i type, it will not accept comma's in between port numbers.
Here is the result
I've tried using comma with no space and just spaces. I have no idea what is going on.
1 Reply
  • plemans's avatar
    does it work if you add them individually?
    I seen a post a while ago that had this same issue that had to add them individual unless they were doing a range
