lorumipsum's avatar
lorumipsum
(RAX45)_slow internet speed on 2.4Ghz
My model isn't listed anywhere that I've seen, but I think the RAX40 is the closest. Mine is the RAX45 6-stream wifi router. I first posted on the general Nighthawk wifi routers group. Thanks michaelkenward for your advice to post here instead and for your clarifying questions.
I got this router in February and immediately had issues with very slow speeds on the 2.4Ghz band only. The problem was solved during my free-tech support period by changing to older firmware (V1.0.2.64_2.0.41). Last week, the slow speeds and buffering returned. I asumed there had been a firmware update and that's what cause the return of super-slow speeds.
I changed back to firmware V1.0.2.64_2.0.41, which had previously solved the problem (I also turned off auto-updates). This time the solution did not work. My download speed is often under 10Mbps, again (last check it was 9.54). I have no idea what to do now. Please help!
Modem: Hitron EN2251 -- it is not also a router. It has one ethernet port and a couple of voice inputs.
  • plemans's avatar
    Its only speed issues on the 2.4gh?
    have you tried changing which channels you were broadcasting on?
    After the firmware change, did you do a factory reset and reinstall (not from a backup)?
    • lorumipsum's avatar
      lorumipsum
      Yes - speed issues are on 2.4 only.
      I had been on channel 9 when things were going well. Promped by your question, I looked again and was back on auto. I have changed it to 11.
      I did not do a factory reset, but I did reinstall the firmware.
      I'm hoping the channel adjustment cleans things up. If not, I'll try a factory reset and reinstall.
  • For the 2.4GHz band, manually select a channel instead of using the "Auto" setting, while auto works well in most cases, in heavily congested environments, it can cause issues by simply not finding any good channels and thus constantly scanning and switching channels depending on which has lower airtime use at the given moment which will change often based on other people in the area.
    Also consider experimenting with the 20/40 coexistance setting. sometimes even in congested situations, it can provide a good speed boost, especiallly if neighboring APs are fairly close to the noise floor.
    Beyond that, when it is performing slow, check other WiFi drvices on the same band to see if they are having similar slowdowns.
    If it is just a single device, then I recommend also using the debug page on the router at routerIP/debug.htm and start logging, and during that process have the device in question disconnect and reconnect a few times. Then check for entries listing the device's MCS rates. Some WiFi adapters will behave strangely or simply not report all supported rates, or engage in other behavior that causes a very low PHY rate to be used, in some cases, it could simply be a driver issue with the WiFi adapter. I have seen this happen a few time with some of the more obscure WiFi chipsets.
      lorumipsum
      I was on channel 9 before, but it seems that was reset to auto with the firmware update (maybe?). I have switched it to 11.
      Okay -- what is that, where do I find it, and what do I need to do? (Sorry, not that knowledgable)
      Everything slows down at once, across all decvices. Thanks for being so thorough!
      • Razor512's avatar
        Razor512
        Prodigy
        For the 20/40 MHz coexistence, it is a setting in the WiFi settings menu. It will be titled "Enable 20/40 MHz Coexistence" and will be enabled by default. That setting will cause the router to use 20MHz channel width instead of 40MHz channel width, thus half the throughput if it detects any overlapping APs. In a truly congested environment, 40MHz can slow you down, as additional airtime sharing will take place, but if the neighboring APs are far away, then that airtime sharing issue may not happen and you will get a nice performance bump.
        Beyond that, try specifying a channel manually.
        Also if unchecking the 20/40 MHz coexistence does not fix the issues, then check it again, as it is a useful feature in the vast majority of cases.
