earthbound's avatar
Apr 19, 2021
RAX45 Slow Speeds
I just upgraded my comcast connection from 200mbps -> 400mbps. Since then, I am able to get 450+ mbps straight to my computer bypassing the router. When the router is connected (even with firmware updated, AND factory reset), I can only get around 70-80mbps to the computer via wifi. What gives? I was getting 170mbps yesterday before the Comcast upgrade. They see no issues on their side (and I don't either...).
  • plemans's avatar
    Are you testing over 2.4ghz or 5ghz?
    2.4ghz is much slower and sensitive to interference
    • earthbound's avatar
      earthbound
      Guide
      It's abysmyl on both. Just tested it and I"m getting 47 on the 5G. I can't have this...
      • plemans's avatar
        Since you upgraded you servcie, did you try a factory reset and reinstall?
