GaryLC
May 30, 2021Aspirant
RAX45 "The IP address conflicts with the WAN IP subnet. Please enter a different IP address."
I am trying to add a Netgear Nighthawk RAX45 WiFi-6 to my network
My modem is a Modem/Router Netgear N450 (Cox)
There is also a Router Belkin 54G F5D72304
When I get this working, I want to replace my Netgear N450 with a Netgear CM1100.
(my N450 has modem/wireless router/4 ethernet ports. The CM1100 is a modem only and I can't jump back and forth between modems with Cox until I get it working so want to get the RAX45 working with the N450 before I make the jump to the new modem.)
I currently have everything working on a local net of 192.168.56.xxx
There is a lot of detail here but most of the posts I see ask for this anyway. My local IPs are broken down in segments as follows:
Fixed IP |
192.168.56.1 | Netgear N450 |
192.168.56.2 | reserved |
192.168.56.3 | reserved |
192.168.56.4 | reserved |
192.168.56.5 | reserved |
192.168.56.6 | reserved |
192.168.56.7 | reserved |
192.168.56.8 | reserved |
192.168.56.9 | reserved |
192.168.56.10 | reserved |
192.168.56.56 | Belkin |
192.168.xxx.xxx | Netgear Nighthawk | RAX45 WiFi-6 | 192.168.56.200? |
192.168.55.11 | 192.168.56.55 | N450 | DHCP |
192.168.56.57 | 192.168.56.100 | Belkin | DHCP |
192.168.56.201 | 192.168.56.254 | Netgear Nighthawk | DHCP |
Printers |
192.168.56.151 | HP8720 |
192.168.56.152 |
192.168.56.153 |
192.168.56.154 |
192.168.56.155 |
192.168.56.156 |
192.168.56.157 |
192.168.56.158 |
192.168.56.159 |
192.168.56.160 |
NAS |
192.168.56.13 | WD My Cloud |
192.168.56.161 |
192.168.56.162 |
192.168.56.163 |
192.168.56.164 |
192.168.56.165 |
192.168.56.166 |
192.168.56.167 |
192.168.56.168 |
192.168.56.169 |
192.168.56.170 |
Router Netgear Nighthawk RAX45 WiFi-6
Default: IP Pool Starting Address: 192.168.1.100 IP Pool Ending Address: 192.168.1.149
Desired: IP Pool Starting Address: 192.168.56.201 IP Pool Ending Address: 192.168.56.254
Anytime I try to set the Lan IP address to 192.168.56.200, I get the "The IP address conflicts with the WAN IP subnet. Please enter a different IP address." error.
I have seen multiple solutions, mostly dealing with DNS server settings. I haven't found any combination of Server Settings that work. Here is some of what I have tried.
Router Information:
MAC Address | 08:36:C9:8E:5E:43 (MAC address on the Box) |
IP Address | 192.168.1.1 |
Internet Port
MAC Address | 08:36:C9:8E:5E:44 (Router Mac Address) |
IP Address | 192.168.56.31 |
Domain Name Server | 68.105.28.11 |
When I go to Advanced/Setup/LAN Setup and try to change the IP address to 192.168.56.200
If I change the IP address to 192.168.55.200, the router is happy and reboots to apply the setting.
Of course, I won’t be able to see anything else on my network.
Basic/Internet/Internet Setup
Internet Setup
Internet IP Address
Get Dynamically from ISP
Use Static IP Address
IP Address 192.168.56.31
Gateway IP Address 192.168.56.1 (the N450)
Domain Name Server (DNS) Address
Get Automatically from ISP
Use These DNS Servers
Primary DNS 168.105.28.11
These settings have no affect whether I use automatic or static settings, so DNS server doesn't seem to fix it.
There is nothing else in my local LAN that is using the 192.168.56.200 - 192.168.56.254 address but I still get the error and no indication of what is causing it.
How can I get this to work with 192.168.56.?
Also, what is with the MAC address?
08:36:C9:8E:5E:44 (Router Mac Address) on the Internet port.
There must be 2 MAC addresses but what are they?
"N450" is a speed, not a model number. Look for "Model" on the
product label. Something like "CG3000D", perhaps?> [...] want to get the RAX45 working with the N450 before I make the
> jump to the new modem.)Cascading multiple routers can cause multiple problems, especially if
you try to jam a square peg into a round hole.If you want to use the RAX45 as a router with your old modem+router,
then the reasonable thing to do would be to configure your old
modem+router as a modem-only. You might then have a chance of
configuring the RAX45 with your desired LAN address scheme, without the
conflict with with your old modem+router which is using the same scheme
in a different place (hence, "The IP address conflicts with the WAN IP
subnet. Please enter a different IP address.").
Visit http://netgear.com/support , put in your (actual) modem+router
model number (or something very like it), and look for Documentation.
Get the User Manual (at least). Read. Sadly, I saw nothing there like
what I expected to find, so it's not obvious that that thing has a
modem-only mode. You might be able to get close if you configure
the thing with NAT disabled, and a LAN subnet other than your usual
"192.168.56.*". (I'd try a settings reset, to restore its default
settings, then disable NAT, then connect the RAX45 to it, and see what
happens.I'd also save the configuration of your old modem+router before doing
any of this, so that you could more easily put it back as you had it.According to its User Manual, the CG3000Dv2 is so ill-suited for use
in this mode, that I'd go straight to the new modem and new router, and
run the grand experiment, rather than play with novel ways to simulate
a CM1100 using your old modem+router. You might need to call Cox a few
more times, if you need to switch back and forth, but I'd take the
chance.- GaryLCAspirant
Netgear N450 is a CG3000Dv2
I will work on disabling the CG3000Dv2 router.
The problem I had with Cox is that when I first tried to enable the Netgear CM1100, it got part way through and then wouldn't complete the connection. Had to call Cox to trouble shoot. He didn't find anything obvious so we put every thing back to the CG3000Dv2. His suggestion was a service contract to track down the problem. I don't want to be completely down for several days while I trouble shoot connection problems.
- GaryLCAspirant
Trying several settings to disable the CG3000Dv2 router part of the modem. Not having much success. Somehow, I managed to change the router address and now I can't connect at all. Will take time off work and go home and work on it. Think the only way I can get to the router now is to do a full reset. I am connected through a direct lan connection,not wireless.
I have no idea how the IP was changed. It may have happened when I disabled NAT. But I can't connect and have no way of determinging the current IP address. What ever it is, it is not 198.168.56.xxx. I have some internet connection but it is limited and some sites, like Netgear, won't respond at all. So at the moment, all if FUBAR. So will see what happens with a factory reset and then try to reconfigure to get back to where I was.
Have had good results with Netgear in the past which is why I went that way this time. But really frustrated with an error message that won't give you any indication of how to fix it. Looks like trying to upgrade with the Nighthawk RAX45 was a bad idea. Maybe better to start with a brand new network. Between computers, NAS, TVs etc, I probably have 50 devices potentially on the network. I don't wan't to have to build everything up from scratch.
