roro99's avatar
roro99
RAX45 VPN software recommendation
Hi,
I am interested in installing a hassle free VPN on my RAX45.
Any recommendations for someone who is not so "techie"
Thanks,
roro99
  • roro99 wrote:
    Hi,
    Thanks,
    roro99
    The OEM firmware on your router includes a VPN server option you can enable and configure.  That will allow you to access your LAN from outside on the internet.
    If you are looking for a VPN service (Nord, Express, Surfshark) , you will have to contact the individual vendors to see if they have firmware for your specific model router.
  • roro99 wrote:
    Hi,
    Thanks,
    roro99
    • roro99's avatar
      roro99
      Thank you very much, I will investigate those options.
      I apprecieate your response.
      roro99
      • Kitsap's avatar
        Kitsap
        Master
        A couple of things to keep in mind.  Installation of third party firmware will void your Netgear router warranty if there is any left.
        When you install third party firmware, make certain you have a clear exit strategy in place to get back to OEM stock firmware.  This includes having downloaded any files required.
