RAColling
Feb 13, 2022Aspirant
RAX48 Hangs
Actually an RAX48. About 3 days ago it started hanging every 2 or 3 hours. To fix I would pull the plug and reboot. After applying Firmware update V1.0.5.106_2.0.70. It kept hanging at about 8 hours.
I found this message in the log..."[DoS attack: RST Scan] from source 23.45.39.193,port 443 Sunday, Feb 13, 2022 15:26:09"
Could this be the problem? Is there anyway to stop this from happening?
Have to do a whois lookup on that IP address to see where it's coming from...
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.A factory reset maybe needed.
- RACollingAspirant
RAX48 -
I did all that early on. I am going to do that again since the first time it was before the router update.
