SurfBird's avatar
SurfBird
Follower
Nov 06, 2022
RAX48 Held reset too long and now power light is solid red
I was having troubles with the router. I reset it once and it did not work. So I tried again and I held it longer in case that somehow makes a difference. Now there is only a solid red light that turns white periodically (maybe for 3 seconds every 30 seconds). Did I brick this device? is there a solution?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have probably put it into "recovery" mode.
    It might be simply a case of rebooting it. Have you tried that?
    If not, can you access the browser graphical user interface (GUI)?
