davesolo
Jan 22, 2023Aspirant
RAX48 internet dead
All the lights are on and isp service is up and running. I can’t contact support because I don’t have a contract or whatever. Any advice? Nighthawk AX6 6-Stream AX5200 WiFi Router (RAX48) Tha...
michaelkenward
Jan 23, 2023Guru - Experienced User
What do the lights look like? The colour?
The first thing to try is a network reboot.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
For more detailed troubleshooting, start with the usual boilerplate questions.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
michaelkenward
