maarkr
Feb 26, 2026Aspirant
RAX48 VPN?
I want to get a VPN provider but I read online that Nord or Express VPN does not work with the RSX48 model. Is there a VPN that works with this model?
CrimpOn
Feb 26, 2026Guru - Experienced User
There are two types of VPN:
- VPN Client. This is software installed on a device to allow it to connect to a VPN Host. Netgear does not provide VPN Client software for any routers.
Any device on the network can install VPN Client software and the router does not interfere in any way with that connection working as intended. So, you can sign up for Nord or Express VPN and use it on any device that you want to.... except the router itself. - VPN Host. This software allows clients to connect from remote locations. Netgear provides OpenVPN Host software for routers. This allows clients who are not connected to the local network to make a connection through the internet to the router, which then allows them access to the local network.
Rather than install a VPN Client on every computer, laptop, phone, etc., some people would rather install a VPN Client on their router so that every device connected to the network can use the VPN connection to access the internet without installing any software on individual devices. (and, also, without having to pay a license fee for each of the devices). Alas, Netgear does not support this feature.
