maarkr
Feb 26, 2026Aspirant
RAX48 VPN?
I want to get a VPN provider but I read online that Nord or Express VPN does not work with the RSX48 model. Is there a VPN that works with this model?
Feb 26, 2026Guru - Experienced User
Usually better to find out what VPN provider you want to use and what devices is compatible with their service. You can always use the RAX in access point mode and have a different router as host.
I built a small n150 router that I can host pretty much whatever VPN I want and then just use my netgear routers as access points.
