maarkr
Feb 26, 2026Aspirant
RAX48 VPN?
I want to get a VPN provider but I read online that Nord or Express VPN does not work with the RSX48 model. Is there a VPN that works with this model?
Feb 27, 2026Guru - Experienced User
maarkr wrote:but I read online that Nord or Express VPN does not work with the RSX48 model.
It would be helpful if you clarified what you mean by "does not work". While you cannot install Nord and Express VPN on the router, Express VPN and Nord will work when installed on clients connected to the router.
Are you wanting
- remote access to your home network?
- all home internet traffic to use the VPN with no software installed on the devices?
- VPN software on some or all client devices to work when the VPN software is enabled on those clients?
