t1pper's avatar
t1pper
Follower
Mar 06, 2021
RAX50 - AX5400 5GHz timeouts
I'm having an issue with my RAX50 and my 5GHz network. My 5G network works fine for any device when that device is newly connected to the 5G network. Then over time the network becomes more and more unresponsive until all network traffic to that device times out. This happens on all devices that attempt to use the 5G network, iPads, intel Windows 10 PCs, and iPhones. All connecting devices updated to latest OS's. The distance from the router doesn't affect the outcome, you could be within a couple of feet of the router and this situation occurs. The device signal indicators show that the devices have good signal strength, and in the case of desktops they never move.
The 2.4GHz network does not exhibit this behavior.
Latest RAX50 firmware installed, V1.0.2.82_2.0.50, but issue has been happening since I installed the RAX50 and over several firmware updates.My 5G network on previous Netgear AC1900 router worked fine until RAX50 replaced it.
Fragmentation Length: 2346
CTS/RTS Threshold: 2347
Preamble Mode: Long Preamble
Thanks!
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello t1pper,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
