jp256's avatar
jp256
RAX50 5GHz not connected to internet
RAX50 suddenly lost 5GHz connection to internet. 5GHz signal is rated "excellent" by client devices but client devices using 5GHz network can no longer connect to internet. 2.4GHz works fine and client devices using 2.4GHz network can connect to internet. All router settings appear normal. Did something in the router fail? Did a file get corrupted? Ideas?
  • The modem is made for the ISP (Spectrum) but does show the mfr name. Model# may be "PC15". Nothing on MAC and S/N label says Model #.
    Channels are AUTO (7) and 36. Was using 44 and working well until problem with internet connectivity developed. Also tried 40 and 48, but still no internet connectivity.
    Ch 7 is working well ("Good" signal rating from client devices).
    Ch. 36, 40, 44, 48 are all rated "Excellent" by client devices, and they can connect to 5GHz, but it will not connect to internet.
    I have not yet manually loaded newer version of FW, and have not tried factory reset. Will do when I have enough time to reconnect all client devices.
    Thanks for your suggestions.
    • FURRYe38's avatar
      Wondering if its a Hitron, They make most of specturms internal modems. Hard to tell sometimes of the brand as sometimes they don't put good sticker info on the modem. Some they do.
      Gotta picture of it?
      Try 1, 6 or 11 on 2.4Ghz. Channel 7 is a sub channel used by the system and not handled well by client devices.
      When you can, update FW manuall using MS Edge for Firefox browser and then factory reset and setup from scratch.
      If you see protection engine on the routers web page, you can disable it and see if this helps any after you have updated the FW and reset it.
  • FURRYe38's avatar
    Brand and model# of ISP Modem or ONT that the router is connected too?
    What channels are you using on the router? Try 1 and 40 or 11 and 48?
    After manually loading FW, did you perform a power OFF of the router and ISP modem for 1 minute then back ON?
    Try a factory reset and setup from scratch?
  • The RAX50 is well beyond the warranty period, but your suggestions sound reasonable.  If the update doesn't help, I'll do a factory reset when I have time to reconnect all the clients. Thanks for your help.
  • All devices connected to 5GHz network are affected: No internet connection. No change after rebooting router.
  • RAX50 suddenly lost internet connectivity but only for the 5GHz network. The 2.4GHz network is fine. Maybe it's a firmware problem? Router has Firmware Version V1.0.17.142_2.0.100. The Router Firmware Update tool says: "no new firmware version available" but Netgear Support website lists V1.0.17.144 as the latest version. Before I circumvent the Router Firmware Update tool to manually download and install version .144, I'd like to know why I got the "no new firmware" message. Am I likely to make matters worse by manually installing .144?
    • jp256's avatar
      jp256
      Thanks for this helpful information. I'd rather not complicate things by manually updating firmware if the update will not correct the 5GHz malfunction. Release Notes for .144 firmware says it fixes security vulnerabilities. Any idea what vulnerabilities? In other words, how essential is the update? If a manual update to .144 creates problems, where can I find instructions and firmware to return to the .142 version?
