khalilkhalil
Jul 19, 2022Guide
RAX50 AX 5400 fails on 5G
This RAX50 has been a nightmare on the 5Gig as it constantly drops. I had it set to smart which selected 2.4 or 5 GHz depends on the device but that was no good either. But now I notice that the 2,4 Gig is always up without issue. only -5G constantly drops and is unusable. All devices drop not just one. FW: V1.0.11.112-2.0.77. I rebooted it a dozen times, did the factory reset, and reloaded the FW but no change. Killed AX and other coexistence 20/40 but no change. Macbook networkQuality fails, and speedtest keeps saying no internet. I mean when on 5G it fails to connect to 192.168.1.1 most of the time and if it does for a minute it fails after 5 mins.
Did you try downgrading the firmware? (a version or 2 )
Can you share the location I can get older FW for this router? The downloads location only has the one from June 2022 which I am using, as well as release notes for older FW but not the FW itself.
Nighthawk RAX50 | WiFi 6 Router | NETGEAR Support
click on downloads.
then click on +view previous versions
I just checked and it opened fine for me. There's a download button.
If its not showing, try a different browser.
