otakukj
Jun 27, 2023Aspirant
Rax50 bricked? Doesn't appear after firmware upgrade attempt
Just tried to install new firmware version, after the install, it said successful and that I needed to restart the hardware. Restarted it but now the device doesn't appear in the wifi selection menu. ...
otakukj
I checked the underneath the router but I didn't see either v1 nor v2 so I assume it is v1. At the time I got it I hadn't heard of another version. I was upgrading firmware from version 386.5_2 to version
RT-AX58U_388.2_2_puresqubi.w
Jun 27, 2023Guru - Experienced User
If you don't see a v2 then it should be a v1 and you should use v1 FW from this post seen here:
RT-AX58U_388.2_2 is NOT a valid FW version. This looks like a ASUS router mfr FW name version. Would NOT be compatible on the RAX50 router.
- otakukjJun 27, 2023AspirantOK thank you I appreciate the quick response I'll try the firmware from the link. One question though how can I access the router to install the firmware from there? Since the router no longer shows up in my choices for a wifi connection. I assume I'll probably need to use a USB stick or something?
- FURRYe38Jun 27, 2023Guru - Experienced User
So a factory reset on the Router by pressing the reset button for 10 seconds then release and connect 1 wired PC to the back of the router you can't get access to 192.168.1.1 at all in any web browser?
- otakukjJun 27, 2023AspirantCorrect. I will keep trying a few more times but using a web browser and trying 192.168.1.1 doesn't seem to work when connected to a laptop directly by LAN cable . I tried changing LAN ports also just to rule that out but so far, no difference, nothing loads up when I put in the ip address in.
- michaelkenwardJun 28, 2023Guru - Experienced User
otakukj wrote:
Since the router no longer shows up in my choices for a wifi connection. I assume I'll probably need to use a USB stick or something?It is a bad idea to update firmware over wifi. It can fail more easily than a wired connection.
There is no USB option.
For truly stuffed routers, the standard trick is to try TFTP:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
- otakukjJun 28, 2023AspirantOK thank you. I'll look into it and see if I can figure it out.
