iwantseth
Jan 30, 2025Initiate
RAX50 remote management
Have RAX50 - stock firmware, updated to V1.0.16.132_2.0.92
I want to manage it remotely. I don't see a remote management option.
Is the only way to do this is to enable VPN access?
NG removed web page remote access from there routers a few years ago. Only remote access is with the Nighhawk app and it has limited features.
You'll have to check out OpenWRT or DD-WRT to see if they support this model router.
Good Luck.
- iwantsethInitiate
Wondering if anyone has installed 3rd party firmware.. if so - any recommendations would be helpful.
Good Luck.
