jtompson
Aug 22, 2020Aspirant
RAX50: Wifi becomes unresponsive daily
Purchased the router 3 days ago. At least once a day (usually at night, but that might just be a cooincidence) wifi channels (2 and 5GHz) become unresponsive.
- The ssid shows up, but they cannot be connected to.
- Existing devices that are already connected stay connected, but there are no returned packets.
- I still have internet over wired connection when this happens.
If I wait long enough (usually an hour or so), it eventually comes back. If I reboot the router, it comes back.
Any ideas what's going on? I've tried disabling AX features. I've tried turning beam forming on and off. Not sure what to try next.
- jtompsonAspirant
- Christian_RNETGEAR Employee Retired
HI jtompson,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
http://www.netgear.com/support/contact.aspx
Christian
