N1PS
Oct 22, 2020Aspirant
RAX50S router unidentified network
I recently purchased and installed this router. There are about 10 devices connected to the router at various times. The PCs at times lose the internet and display "Unidentified Network" when you hover the mouse over the PC wifi connection icon. Nothing seems to work to get the connection back EXCEPT either resetting the router (unacceptable solution) or connecting to the 5GHz connection (for those PCs that have this option.
I looked over all the device IP addresses and there are no conflicts that I can find. This is irritating and must be fixed. The old less capable Cisco router never did this.
I thought I would start here before goimg to support.
Peter
- Dan32Apprentice
Have you ever updated the firmware? The latest version as of today is 1.0.2.72. It has a massive list of fixes.
If you are on this version, you might want to try to reset the router to factory defaults and re-install it again. Then re-configure from scratch any custom changes you previously made. Do not save and reload a configuration file. If not, then do the same.
The other thing to look at, is your Wifi drivers on your PC's. If you are using Intel AX cards, or any of the newer Intel AC cards that all use the same Proset drivers, you might want to head over to the Intel site and grab the lastest drivers (and for bluetooth as well as they are separate). You won't necessariy get the latest drivers from Windows Update.
- N1PSAspirant
TNX. The router firmware is up to date and the PCs have the latest drivers.
- KillhippieProdigy
Have you reset the router via the small pinhole in the back to factory settings
