CrazyVegan's avatar
CrazyVegan
RAX54S vs RAX29?
What are the main differences?
  • plemans's avatar
    RAX54: iFi 6 (802.11ax) dual band WiFi (AX5400)
    - 2.4GHz AX: 2x2 (Tx/Rx) 256-QAM
    20/40MHz, up to 574Mbps
    - 5GHz AX: 4x4 (Tx/Rx) 1024-QAM
    20/40/80/160MHz, up to 4.8Gbps
    RAX29: WiFi 6 (802.11ax) Dual Band WiFi (AX2400)
    - 2.4G: 574Mbps, 40/20MHz
    1024/256-QAM
    - 5G: 1800Mbps, 80/40/20MHz
    1024-QAM
      • michaelkenward's avatar
        michaelkenward
        CrazyVegan wrote:
        So should I pay the extra $30 for the RAX54S? If so, why?
        What do you plan to do with this thing?
        Broad brush questions aren't amenable to detailed answers.
        What do the reviews say?
        What have you discovered from wandering around in this place?
        Which would look best on the shelf? Three or four antennae?
