VRixxo
May 28, 2026Aspirant
RAX54v2 Locked to Canada
Hello, I live in a area with high interference and was doing latency sensitive task so decided to use 160MHz and DFS. Unfortunately the router I bought from Amazon is somehow region locked t...
schumaku
May 29, 2026Guru - Experienced User
FURRYe38 wrote:And this latest version won't load on it?
Of course not.
VRixxo wrote:And I've updated the Firmware to the latest 1.0.17.144
Your router does show RAX54S or RAX54Sv2 on the label?
Does Amazon indicate you had ordered and received a RAX54Sv2?
Was this an Amazon "open-box" deal, or was the box and the inner bag opened before you received it?
Does Serial number and MAC address printed on the labels match to the Serial number and MAC address on the router Web UI?
In case all this does not match, this looks like a classic, albeit frustrating, case of hardware swapping fraud (sometimes called "box switching").
Here is a breakdown of what is happening, why the firmware won't work, and how you can verify if you've been scammed.
The Core Issue: Hardware vs. Firmware
The Netgear Nighthawk RAX54S and the RAX54Sv2 (Version 2) may look identical on the outside, but they are entirely different machines under the hood.
- RAX54S (v1): Uses a specific chipset and runs firmware in the v1.0.x.xxx family.
- RAX54Sv2: Uses a completely different processor/chipset design and runs firmware in the v1.1.x.xxx family.
Because the underlying hardware architecture is different, you cannot cross-load the firmware. The router's system will reject it to prevent "bricking" (permanently ruining) the device.
The "Swapped PCB" Scam Explained
What the forum user is suggesting is a known issue with Amazon returns:
- A "bad actor" buys a brand new RAX54Sv2 from Amazon.
- They take it home, open the case, and swap the internal circuit board (PCB) of their old, broken, or cheaper RAX54S (v1) into the new v2 plastic shell. (Alternatively, they just put their old v1 router inside the new v2 box).
- They return the Franken-router to Amazon for a full refund.
- Amazon’s return department checks that a router is in the box, misses the internal swap, and restocks it—often selling it as an "Open-Box" deal or even mixed back into "New" inventory.
Ultimately, the innocent next buyer (VRixxo) ends up with a router that says "v2" on the outside, but is actually a "v1" on the inside.
How to Verify if You Were Scammed
If you suspect this has happened to you, perform these three quick checks:
- Check the Web UI vs. Physical Label: Log into the router's admin dashboard (usually 192.168.1.1). Look at the Serial Number and MAC address listed digitally on the screen. Now, look at the sticker on the bottom of the actual router. If they do not match, the hardware has been swapped.
- Check the Firmware Prefix: If the router's dashboard says you are on v1.0.17.144 and it refuses to update to a v1.1.x version, your router is physically a v1, regardless of what the box or plastic shell says.
- Inspect the Packaging: Look for signs of tampering. Was the shrink-wrap missing? Were the internal plastic bags taped shut rather than heat-sealed?
What to Do Next
If the numbers don't match, contact Amazon customer support immediately. Do not try to force the firmware. Tell them explicitly: "I received a fraudulent return. The item inside the box does not match the product description, and the internal serial number does not match the external label." Amazon is usually very quick to issue a replacement or refund for this specific issue.
