mking007
Jun 01, 2025Aspirant
RAX70 - issues since latest firmware update - usb speed dropped massively
Just updated my netgear rax70 router and since the firmware update, the usb speed is only maxing out at 30mb transfer rate, it was 100mb before the firmware update and working fine !
how do i fix this, nothing wrong with the ssd drive via usb to the router
how is it possible to change back to the previous firmware ?
Also there was a issue with the 2.4ghz wifi, the speed was only 3mb ! (1gb connection)
had to manually switch of the 2.4ghz and back on again, and that speed to fix that.
Why aren't firmware releases checked before releasing ???
using cat7 from main pc direct to router.
Rax70 is using - Router Firmware Version V1.0.19.172
- mking007Aspirant
update;
downloaded the previous Router Firmware Version V1.0.15.146 and installed via admin and speed back to 100mb usb drive rate without touching anything.
something is buggy with the latest firmware- FURRYe38Guru - Experienced User
A factory reset and setup from scratch of the router and USB device should have been performed to check the newer FW version.
- mking007Aspirant
i just tried factory the reset and didn't make a difference, poorly tested firmware.
SMB settings is affect the new firmware update
Tests:
Auto mode SMB 2.0 and SMB 3.0 20-25mb read speed, 13mb write speed
force SMB 2.0 and SMB 3.0 52mb read speed, 13mb write speed
disable SMB 2.0 and 3.0 66mb read speed, 13mb write speed
New firmware update is awful, its seems slow as well when trying to access the usb drive, the older firmware is 100mb up and down and no issue. with smb 2 and 3 auto mode.
Time for a new brand of router.
