deepsouth06's avatar
Apr 07, 2021
RAX70 Internet dropping
Ok so Yesterday I went out and bought an AX8 - RAX70 (for some reason its not in the available models) and setup it. All working well until this morning where I would notice my MS Teams would for about 1-2 seconds looks connection. Also another app Trillian was also loosing connection at the same time. Later in the day when both my wife and I were in seperate meetings both our meetings would loose connection for up to 20ish seconds; however the internet never completly went out. If I were to do a speed test I'd get my 100 down and 10 up. I'm really confused as i've never had these problems were only certain apps would drop in and out of connection. Any help would be greatly appricated. I'm already thinking of maybe doing a return but i dont really want to have to do that.
I am currently on Firmware Version V1.0.2.88
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello deepsouth06,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
    • JLit's avatar
      JLit
      Initiate
      Christian_R it great that you refer people to support within the 90 day support period but can someone post the solution to the problem?  I've seen lots of posts but have yet to see a solution or a trouble shooting guide for the problem.  Can you post it?
