philc11's avatar
philc11
rax70 internet speed decreases overnight until reboot
Im using firmware V1.0.1.78 and this is the "latest" today 23Nov20.  At reboot, internet upload and download speeds are great ~ 300MBps or more...after a few hours or overnight, we see a drop to 15-20MBps until reboot (then its back to normal).  How do I read the logs to figure out the problem or where else should I start?  I was on hold for hours last week and the "next level" or level 2 tech was supposed to call back (they did not).  This week, I called back as did my wife for hours and we just kept getting a new level 1 tech person who could not think past the prescribed script diagnostics.  Can anybody help before I pull out my hair and take this back to best buy?? lol....seriously, any suggestions?
  • plemans's avatar
    what modem is it connected to?
    When the speed is dropping, are you connected to 2.4ghz or 5ghz?
    does wired speeds drop as well or just wireless?
    • philc11's avatar
      philc11
      Cable modem model cm1200 connected to the AX6600 (RAX70) wireless router .  Wireless speed on both 2.4 and 5 are slow after a period and I cannot directly connect to either the model or router (plugging in an ethernet cable does not work once the speed decreases).
      • plemans's avatar
        Are you using wan port aggregation between the RAX and the CM1200?
