MontanaMike's avatar
MontanaMike
RAX75 Latest Firmware April 2020
Good evening.  New to Netgear equipment and I have a question related to firmware.  No firmware is available to upgrade to from within the admin section of the RAX75/AX5700 (says I'm running: Firmware Version V1.0.1.70_1.0.30) but when I go to the support site and the product support page it shows this version as the most current: Firmware Version 1.0.2.76 so I'm wondering if I should load that or leave it alone.  I am having some random weird issues with internet connectivity so forth.  I was reading on other RAX75 threads that I should do a factory reset which apparently seems to resolve issues.
Any help would be appreciated.
  • This happens frequently with NETGEAR. Sometimes they either forget to push the new version to the update server or are too late in doing it but it's up on the site before that. Sometimes a version gets pulled back quickly too because of issues. I suggest you download it and manually flash it and do a factory reset & reconfigure from scratch
