BuggyRAX75's avatar
BuggyRAX75
RAX75 shows dates 900k+ years in the future in logs
My RAX75 that has the latest firmware and shows dates of 900k+ years in the future when it drops wifi and the UI becomes very slow.
The wifi radios drop randomly and sometimes do not recover fully forcing a hard reset.
Firmware Version V1.0.10.140_1.0.79
Can this 2022 era firmware be fixed by netgear or should I return the device to costco?
900 thousand years in the future
  • Have you factory reset the router and setup from scratch is last FW update?
    Happens in other browsers?
    DarrenM
    • BuggyRAX75's avatar
      BuggyRAX75
      I will factory reset it and see if that does anything.
      The browser used to view the log should not change the log screenshot.
      • FURRYe38's avatar
        Guru
        Check other browsers to be sure.
        How was the FW updated on the router, auto update or manually?
